Discussion topic: NetFlix not working in Add on SkyQ box
Message posted on 20 Jun 2024 09:33 PM
NetFlix not working in Add on SkyQ box. It is very irritating. Sometimes it works, most of the it doesn't.
Can you help?
Message posted on
21 Jun 2024
07:55 AM
- last edited:
24 Jun 2024
10:48 AM
by
Daniel-F
Re: NetFlix not working in Add on SkyQ box
@florence023 wrote:
Hello, @Milan-Suter
If Netflix continues to malfunction, consider reinstalling the Netflix app. Navigate to the Apps section on your Sky Q box, locate Netflix, and reinstall it to potentially resolve any app-specific issues.
Best Regard,
florence023
Not sure why you suggest this, we have no control or access to installing or re-installing apps on Sky Q
Message posted on 21 Jun 2024 05:41 PM
Can you help?
@Milan-Suter if you are getting the red spinning circle then have a read of the link below especially post 2 marked as the answer
https://helpforum.sky.com/t5/Sky-Q/Netflix-Red-Spinning-Circle-on-Launch/td-p/4428388
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
