Discussion topic: Neee replacement sky a remote
This message was authored by: Re5
Need replacement sky q remote done online form it does not work
Re: Neee replacement sky a remote
@Re5
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
If that form isn't working it may be quicker to purchase a new remote from a retailer or larger supermarket.
▪️I AM NOT A SKY EMPLOYEE (undercover or otherwise) ▪️
Avatar for Re5
I've rang sky and they sent replacement next day thanks !
