Discussion topic: Need to change my cost plan and issues with signal
This message was authored by: MikeBaker1
Paying too much and repeated signal loss
Re: Need to change my cost plan and issues with signal
@MikeBaker1 wrote:
Paying too much
If you’ve been a customer for a while a discounted deal may have recently expired or be ending very soon. Sky will have told you the date the discount was ending when you took it out. Try comparing a previous bill to your latest bill and see where the amounts differ
www.sky.com/bill.
If your discount has ended you will need to contact Sky to try to negotiate a new deal which will require another 18 month minimum term contract. Sky are not obliged to offer you another discount so if you’re offered something acceptable you need to agree to it there and then because if you decide to think about it the offer may no longer be available when you call back.
You can either call Sky or use the following link
https://www.sky.com/help/articles/cancel-sky-tv#contact-leave
”No signal” tends to be a message from your TV (in which case check the cables going to the TV).
A “no satellite signal” message relates to your Sky box.
Whenever a “no satellite signal” message is displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye and could only affect one or two channels). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Hi @MikeBaker1   You are not talking to Sky, this is a community of customers.
