Discussion topic: Need a new additional box
This message was authored by: GATK1
How do I get Sky to replace a box
Re: Need a new additional box
@GATK1
What box is this that you need replacing ?
Avatar for GATK1
A 3rd Sky Mini Box
You might have to call Sky about this so under “Need more help” at the bottom of this page might be the number to use:
https://www.sky.com/help
Or via the phone 150 is the free number to use from a phone that has a Sky mobile sim in it or Sky Talk phone.
Sky Assistant is also available 24 hours a day on sky.com/help with rapid responses.
@GATK1 wrote:
A 3rd Sky Mini Box
hi @GATK1
What actual probelms do you have with this mini box ?
Avatar for GATK1
It's a booster box, and it's simply not working
If it's a Sky booster box you are having issues with, have you tried a reset as described here;
https://www.sky.com/help/sky-tv/sky-tv-q/fixing-sky-q/fixing-connectivity/fix-connection-problems-wi...
Avatar for GATK1
I'll try, thank you
