Discussion topic: Sky Q without Sky Broadband
This message was authored by: Loobs72
Hi.  I am changing my home broadband away from Sky.  Is there anything I need to know regarding connecting my Sky Q and mini boxes to a third party provider?  Thanks
This message was authored by: Doc5907
Re: Sky Q without Sky Broadband
@Loobs72 nothing special involved. You can follow the link below.
Connecting your Sky Q box to a non-Sky broadband router | Sky Help | Sky.com | Sky Help | Sky.com
Sky Q 1TB UHD
LG TV
Sky Mobile
With a non-Sky network the main box will only connect over 2.4GHz band.
Also, the mini boxes will use a direct connection to the main box (and not your broadband) - 5GHz ch 36 default.  If the mini's where relying on the Sky network for reach then you may have issues if the mini's are too far from the main box.
