Discussion topic: Need a engineer cut wire on dish
This message was authored by: lynn+rimmer
Need a engineer to my home cut a wire to the dish no sky at all
Re: Need a engineer cut wire on dish
@lynn+rimmer
You will need to contact Sky as an engineer can not be booked via here.
150 is the free number to use from a Sky Mobile or Sky Talk phone otherwise under "Need more help ?" link at the bottom of the page on this link is the number to call Sky on:
https://www.sky.com/help/home
@lynn+rimmer
Expect them to be busy following the recent storms so there may be a longer wait than normal.
Depending where it was cut you might be able to repair it. Inside the house would be easy.
