Discussion topic: I have a 'technical faukt on my sky mini box and have reaet and re connected my mini to Q box and it
Message posted on 10 Nov 2023 09:42 PM
I have a technical fault message on my sky mini box I have reset and reconnected it but message is still there
Message posted on 10 Nov 2023 10:25 PM
Re: I have a 'technical faukt on my sky mini box and have reaet and re connected my mini to Q box an
Hi @Fluffybunnu
Reboot the mini as above.
