Discussion topic: Some TV channels are not working (Channel 5)
This message was authored by: DJJenkins
Channel 5, Sports 2 (PL HD), sky Atlantic HD to name a few - no idea why it says no satellite signal
Re: Some TV channels are not working (Channel 5)
@DJJenkins
Typically that's because the dish has moved slightly out of alignment, and needs adjusting by an installer with a signal meter.
Avatar for DJJenkins
many thanks
This message was authored by: Deedee36
@DJJenkins  As @TimmyBGood  says it's probably a dish issue,I remember last yeah my mother having the same issues on the same channels you have mentioned it turned out that her dish had slightly moved and needed realigned
“Trying to help improve sky glass”
thanks - yeh we've had building work, so probably been knocked
That would do it.  Sky probably won't charge for an installer visit, but you may need to wait for one to be available.
This message was authored by: KC-Bassman
I've been getting the same but for one channel only - 505 (CNN). One minute it was there, now it's not - but I can still get all the other news channels?
is it really a case of the dish has moved slightly which can cause just one channel to stop being available?
Oops - I meant 506! Either way, it is CNN that has gone AWOL!
@KC-Bassman
There are probably others but may be channels you don't watch. If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. If you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
