Discussion topic: My smart tv is going for a repairs how can I connect my skyQ box to an old tv
This message was authored by Mfayaz23 This message was authored by: Mfayaz23
My smart tv is going in for a repair how can I connect an non smart tv into my Q box.
This message was authored by Mark39 This message was authored by: Mark39
Re: My smart tv is going for a repairs how can I connect my skyQ box to an old tv
You don't need a smart TV to connect a Sky Q box. Just connect the HDMI cable as you do with your current TV.
Mfayaz23
That doesn't work. Saying no signal
This message was authored by Laing1 This message was authored by: Laing1
@Mfayaz23 with your TV on and the Q box on showing the green light try press the following on your remote control the home button followed by 1080 then the home button again
...and make sure you're selecting the HDMI input that your Sky box is connected to.
Mfayaz23
If that doesn't work any thing else I can do
Mfayaz23
Previously I have selected both HDMI inputs but both say no signal
Unless there's something else you haven't told us, for example, your Sky Q box wasn't working with your other TV. there's no reason why it shouldn't work with the non-smart TV.
@Mfayaz23
as @Laing1 Says with the SKY Q box on carefully press the following keys in sequence
Home 1 0 8 0 Home
which resets the SKY Q box resolution to one that all TVs with an HDMI input can use
Mfayaz23
Thanks everybody it worked 🥳
This message was authored by PlaygirlCD This message was authored by: PlaygirlCD
we've just tried this same fix and it worked.
thanks!
