Discussion topic: My smart tv is going for a repairs how can I connect my skyQ box to an old tv
Message posted on ‎10 Apr 2023 02:36 PM
My smart tv is going in for a repair how can I connect an non smart tv into my Q box.
Message posted on ‎10 Apr 2023 02:45 PM
Re: My smart tv is going for a repairs how can I connect my skyQ box to an old tv
You don't need a smart TV to connect a Sky Q box. Just connect the HDMI cable as you do with your current TV.
Message posted on ‎10 Apr 2023 03:01 PM
That doesn't work. Saying no signal
Message posted on ‎10 Apr 2023 03:22 PM
@Mfayaz23 with your TV on and the Q box on showing the green light try press the following on your remote control the home button followed by 1080 then the home button again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on ‎10 Apr 2023 04:22 PM
...and make sure you're selecting the HDMI input that your Sky box is connected to.
Message posted on ‎10 Apr 2023 07:40 PM
If that doesn't work any thing else I can do
Message posted on ‎10 Apr 2023 07:41 PM
Previously I have selected both HDMI inputs but both say no signal
Message posted on ‎10 Apr 2023 07:46 PM
Unless there's something else you haven't told us, for example, your Sky Q box wasn't working with your other TV. there's no reason why it shouldn't work with the non-smart TV.
Message posted on ‎10 Apr 2023 07:52 PM
Message posted on ‎11 Apr 2023 03:15 AM
Thanks everybody it worked 🥳
Message posted on ‎16 Jan 2024 08:01 PM
we've just tried this same fix and it worked.
thanks!
