Discussion topic: My skyQ box constantly crashes!
This message was authored by: Hannah101
My skyQ puck constantly crashes, it freezes up completely and has to be unplugged and restarted. It's extremely frustrating!
It is happening multiple times a day, I've tried resetting the box multiple times, updating aswell but it continues.
I think I may have a faulty box, it happens on live tv & apps.
Re: My skyQ box constantly crashes!
@Hannah101  You've posted in the Stream forum but mention Sky Q puck?
Sky Q have mini boxes, Stream have puck, so which do you have?
Avatar for Hannah101
Sorry - it's a mini.
cant believe i got that so wrong!
@Hannah101
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
