Discussion topic: Problem with Error: MR102 on mini-box on Kitchen TV.
Message posted on 23 Apr 2025 12:09 PM
Have not had a problem for months on Kitchen TV Sky Mini-Box. Now keep getting Error: MR 102 shown on screen. Have followed instructions but no joy. Have reset Main Sky Q box, have unplugged Mini-Box & reset, have unplugged broadband & re-set, have checked all leads & connections without any luck.
Message posted on 23 Apr 2025 02:20 PM
Re: Problem with Error: MR102 on mini-box on Kitchen TV.
Hi @AlanG13
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 26 Apr 2025 09:44 AM
Thank you, finally was able to sort out my problem this morning, and now kitchen mini box now re-connected. Thanks again for your help.
