Discussion topic: My sky q recordings are half way through watched and I haven’t even started watching them
This message was authored by Louise+p1 This message was authored by: Louise+p1
Some programs that I record are at 30 minutes or an hour. So I think that's where I last watched them. Then when I get to the end. I realise that I haven't watched it from the start.
Re: My sky q recordings are half way through watched and I haven’t even started watching them
Hi @Louise+p1
Part watched normally happens if you have watched the channel during recording.   This can be briefly or inadvertently.
Also the same can happen if you are tuned to the channel when you set the recording.
This message was authored by Laing1 This message was authored by: Laing1
@Louise+p1 if you channel hop and goto the channel you are recording even for a second the box thinks you have watched the channel and marks it as watched to that point
Louise+p1
But it shouldn't do this. Especially when you have a lot recorded. You end up missing a lot. This technical fault should be fixed by sky. We all pay enough for it!! 😳
This message was authored by PandJ2020 This message was authored by: PandJ2020
No, it's quite deliberate.
No need to miss anything @Louise+p1
All recordings that are shown as part watched have a Watch from start option
This message was authored by pra29 This message was authored by: pra29
How does the above account or the fact that several recordings made during a recent period when we were out of the coutnry show as being part watched on our return?  In a couple of cases alternate recordings of a daily programme show as being mostly watched.  This is definately a fault which Sky should be addressing.
This message was authored by Chodley This message was authored by: Chodley
Do your neighbours have a key?
Can't say I've ever noticed this.
This message was authored by Maris71 This message was authored by: Maris71
I wasn't on the live channel even briefly when I recorded the programme I wanted & it was still halfway through today when I went to watch it. It's annoying & never happened with the old HD box.
This message was authored by Invisiblename This message was authored by: Invisiblename
Do you have a Sky mini box as well which someone else in the household uses?
I am just another Sky customer!
 No mini box. Just the sky q box.
Was the box on but you weren't using it? And may have happened to be on that channel?
No. And anyway lots of people have this fault. Sky need to fix it. Never happened with HD box
Who are these "lots of people" you refer to?  The most common cause of this was explained further up this thread.
This message was authored by Shaun170 This message was authored by: Shaun170
We have this same issue. Random recordings show as part watched even though we haven't watched them and we haven't channel hopped and watched the channnel that's recording. And no, nobody is doing anything on our mini box upstairs. Been happening for a while.
