Discussion topic: Sky remote not turning off LG soundbar
Message posted on 16 Oct 2024 04:15 PM
Hi all,
can anyone help me! My sky remote will not turn off my soundbar even though I have set the remote to control both the tv and the sound bar... it worked perfectly until yesterday until my dog stepped on the remote...
any help would be greatly appreciated !
thanks
Message posted on 16 Oct 2024 04:23 PM
Re: Sky remote not turning off LG soundbar
@get+the+answer wrote:
Hi all,
thanks
Check that both your TV & sound bar have got HDMI control set on.
Unfortunately it may not be 100% obvious what the seeting is - on My panasonic it is called Viera link
Message posted on 16 Oct 2024 04:52 PM
Do I have to have a hdmi cable connecting to both ? Thanks for your reply
Message posted on 16 Oct 2024 05:02 PM
Yes - the SKY remote will only power on/off the TV & it relies on HDMI control to switch the sound bar
Optical cables only carry the audio signal and can't be used for control
Message posted on 16 Oct 2024 05:13 PM
Oh ok. I have to get a hdmi cable then . Thanks for your help
Message posted on 16 Oct 2024 05:19 PM
...seems strange it was working until yesterday though?
Message posted on 16 Oct 2024 06:26 PM
I know.... I should have said that I'm getting audio from the soundbar... it's just the sky remote won't turn off the tv and the sound bar when I do a long press on the power button
