Discussion topic: Sky Q mini blue screen but sound : connecting to Q main box message
Message posted on 11 Jul 2024 08:02 PM
Hi all,
I have been getting blue screen on mini boxes but there is sound . When I power down mini , after reboot clears issue. The issue is occurred at least a few times a week.
the blue screen has message connecting to Q main box.
any ideas
Dave
Message posted on 11 Jul 2024 08:28 PM
Re: Sky Q mini blue screen but sound : connecting to Q main box message
@Dave+Chand wrote:
Hi all,
any ideas
Dave
Hi @Dave+Chand
Try refreshing the connection between your minis and the main Q box.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 15 Jul 2024 12:12 PM
Hi
I have rebooted main box and all minis , but still getting blue screen with Connecting to main box with sound. I need to reboot mini and then it connects properly.
Dave
Message posted on 16 Oct 2024 07:50 PM
Hi all,
still having issues on mini boxes with blue screen but sound working. Fix is to power off mini box and start up again . Note the minis have wired ethernet connection, but still blue screen occurs approximately 2 week.
I guess error must be a software/hardware issue with the minis .
NB the minis are about 6 months old..
does anyone else have the same issue ( blue screen but sound working)
