Discussion topic: My sky q mini box won’t connect despite trying all on line help tools and it’s getting exceptionally
Message posted on 10 Sep 2023 09:07 AM
I haven't been able to connect my sky q mini now for a week . Constantly says no signal. I've tried all the on line tools and recommended steps to reconnect but none of them have worked and do not respond
the box also seems exceptionally hot
I have rebooted the main box and my other Sky q mini is working fine
thanks
Message posted on 10 Sep 2023 09:16 AM
							Re: My sky q mini box won’t connect despite trying all on line help tools and it’s getting exception
thanks
Hi @Jilly3
Have you carried out a Network reset on the problem mini?
You can use the first connected mini for WPS if nearer than the main Q box
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Message posted on 21 Nov 2023 08:56 PM
I have same problem. Minibox is connected to main Sky Q box, network connection is good. Been through all the resets. Tried updating software by the System Info screen and turning off then back on whilst holding box button, both say unsuccessful. Have a "Technical Fault" displayed now. TV guide is complete. Recordings are showing! Had issues with main box recently and engineer says due to 97% usage that's causing a problem. Was going to swap boxes but need to watch programmes first! Also tried connecting via wps and also cable. Not a network thing require booster, given it's connected to Internet. Baffled
