4
This discussion topic has been answered Discussion topic: Intermittent issue with connection between mini box and sky q box
This message was authored by: Mark
I've tried turning tv off (works for a couple of mins) and rebooting the mini box (plug out for 30 seconds). Booster cannot be relocated
Re: Intermittent issue with connection between mini box and sky q box
Hi @Mark
Reboot the mini as above.
If you have a Q booster which is nearer and is connected to your Q box you can use the WPS on that
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can also try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button.
Hi @Mark
Avatar for Mark
Seems to be working so far - thanks
Avatar for Mark
Actually it worked for 10 mins so I moved to the reset and I'm having the same problems. I am on sky broadband and have a sky router already
Hi @Mark
Is your WiFi Booster a Sky Q booster?
If so what has it been connected to?
