1
This discussion topic has been answered Discussion topic: My sky Q remote does not work
This message was authored by: Ralph6320
Hi, the remote for my main sky Q box has stopped working, I've changed battery's but makes no difference.
Re: My sky Q remote does not work
Hi @Ralph6320
Failing this and your remote is completely unresponsive\Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment
In the meantime if you have an Apple or Android device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Hi @Ralph6320
See following link.
