Discussion topic: Unable to watch sky cinema on demand even with full sky package
Message posted on 17 Sep 2025 09:03 PM
Recently recontracted and now unable to watch sky cinema on demand even though i have full sky package uhd , hd, sports literally everything. We have always been able to watch before and i can even download on the sky go app to my phone but when i try to send it to sky box or download on the sky q boxes i get the message about i need to upgrade my subscription. Has anyone had this problem before?
Message posted on 17 Sep 2025 09:33 PM
Re: Unable to watch sky cinema on demand even with full sky package
Hi @DB2586
Have you checked that your package still contains Sky Cinema and the UHD Add on.
You can check this in your Q box in the Home menu under My Sky
Message posted on 17 Sep 2025 09:34 PM
Yes everything is all on there
Message posted on 17 Sep 2025 11:08 PM
@DB2586 Can you watch the Cinema channels live?
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 17 Sep 2025 11:12 PM
Yer literally everything works apart from cinema on demand. I can use it on skygo app just not the q boxes
Message posted on 18 Sep 2025 04:49 PM
@DB2586 You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
