This discussion topic has been answered Discussion topic: My multi room mini box had frozen
Message posted on 28 Jul 2024 09:04 AM
No code it's stuck on sky accessibility sdvert
Message posted on 28 Jul 2024 11:57 AM
try the following steps as below,
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen “Skip & set up later”
- Hold 1&3 to repair the remote control
If 4&6 does not clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control their TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 28 Jul 2024 09:05 AM
Re: My multi room mini box had frozen
Its frozen on a sky accesability ad
Message posted on 15 Nov 2024 01:11 PM
Thank you for your replies Sky go mini box now connected
