Discussion topic: My husband has cut through the sky cable on the external wall of the house severing the connection
Message posted on 30 Jul 2024 11:41 AM
The cable being severed means there is no connection to the sky box
Message posted on 30 Jul 2024 11:49 AM
Re: My husband has cut through the sky cable on the external wall of the house severing the connecti
You will need to call Sky to arrange an engineer. Sky are likely to charge around £65 for this. You could consider a local satellite company but get a quote first.
Message posted on 30 Jul 2024 01:07 PM
@Janet57 wrote:The cable being severed means there is no connection to the sky box
You can get an external coaxial cable connecter to re-connect the wire:
https://www.amazon.co.uk/Coupler-Extension-Connector-Weatherproof-RFAdapter/dp/B07WPKXQV2
And you can connect them using the first set of information here: https://www.wikihow.com/Connect-Coaxial-Cable-Connectors
Message posted on 30 Jul 2024 01:14 PM
Personally, I would not use them without also wrapping the whole joint in self-amalgamating tape as I think there is too much risk of water ingress along the cable
(I have used ordinary F-F connectors that way when I cut through my cable at the end of my garden)
Message posted on 30 Jul 2024 01:18 PM
I purposely suggested external coaxial connectors as per the Amazon link. The reviews seem to be good too to suggest they're waterproof.
Message posted on 30 Jul 2024 01:24 PM
Yes - I am aware. my advice was posted after seeing them but I know it is just my personal opinion
Message posted on 30 Jul 2024 03:19 PM - last edited: 30 Jul 2024 03:33 PM
@Anonymous wrote:...You can get an external coaxial cable connecter to re-connect the wire:
I can understand that if you are attempting to join two F type connectors which have been compressed onto the coaxial cables that are to be joined then this coupler might well achieve a waterproof joint.
But, if you are attempting to join two 'Screw On' F type connectors then you would still be likely to have water ingress between the plastic outer cover of the coaxial cables and the outer of the 'Screw On' F connectors.
Personally I would carefully choose the correct size of Cablecon compression connector which had been purchased with the additional option of an inner rubber seal. The manufacturer claims that this should achieve a seal that will withstand up to 1.3 Bar water pressure, when tightened to around 2.5 Newton Metres, which is a bit more than finger tight.
Godfrey.
Message posted on 30 Jul 2024 03:41 PM
Hi @Janet57 I nicked my cable with my secateurs. I reported this to Sky and they didn't mess about. They replaced the entire cable and didn't charge me anything 😀
