Discussion topic: Can't order Sky Q
Message posted on 30 Jul 2024 03:35 PM
Can't order Sky Q
I had sky for 5 years, cancelled last year and returned all equipment. I've decided I'd like to get it back and want Sky Q, not Stream / Glass.
Whenever you try to add a TV package the store wants to default you to Stream / Glass, how can you order Sky Q?!
Message posted on 30 Jul 2024 03:38 PM - last edited: 30 Jul 2024 03:40 PM
Re: Can't order Sky Q
hi @SB14490
It is not always obvious but the SKY Q page should be available via a dropdown under TV
Anyway - hopefully this link will work for you:
Edit : Even if you can access it we generally advise calling as you may get better deals that way
