Discussion topic: My broadband is working perfectly, however my internet signal constantly drops out on the sky Q box.
This message was authored by: RJM5
My broadband is working perfectly, however my internet signal constantly drops out on the sky Q box. The message on the sreen reads:
"it looks like you do not have internet connection right now. If you're already set up we'll keeping trying to connect. If you have changed your password your internet password or router you will need to reconnect to your network.
Go to settings and check your network connection ststus to reset."
I have follwed these instruction numerouse times but to no avail. Please can you help. I have no connection to on demand services, Sky movies, netfix etc and the TV guide drops out.
Thank you.
Re: My broadband is working perfectly, however my internet signal constantly drops out on the sky Q
Thank you.
Hi @RJM5
