Discussion topic: My SkyQ box goes into standby regularly
Message posted on 23 Sep 2024 10:52 PM
Ok so have seen other posts about this but nothing helps.
My SkyQ box will go into standby while watching live or recorded programs
It may go days without doing it, sometimes does it twice in 30 minutes.
I have had at least 2 replacement boxes, I have reset, hard drive reset and factory reset the current one
Turned off eco mode that is supposed to put it in standby when not in use.
I have updated the software on the box
Different cables have been used with each box
I have tried different hdmi sockets even though sky insist it will only work on hdmi sockets 1
I have "turned it off and back on again" lol, overnight so it is definitely gets a cool down.
It is the only unit on my TV stand so isn't overheating and to help air flow I have made a little stand so air can flow all around it.
This started about 3-6 months ago, so I'm thinking it's firmware causing it.
The replacement boxes are clearly refurbished units as the last one has finger prints all over it and the remote voice control didn't work.
Does anyone one have any idea why this keeps happening and more importantly how can it be fixed
Thanks Paul
sky Platinum VIP
Message posted on 24 Sep 2024 10:11 AM
Re: My SkyQ box goes into standby regularly
If the issue is occurring after the box has been replaced several times perhaps the cause is external?
A few thoughts - maybe the TV is a cause? My TV will put the Q box into standby when I turn the TV off so maybe the TV is sending a standby signal occasionally? Try either swapping the TV - which tbf is a somewhat impracticable solution! - or turning off HDMI-CEC functionality.
Another thought is perhaps there is an issue with the mains? Maybe a spike is causing the box to go into standby. How you would test/check that I have no idea - maybe an extension lead with a mains filter?
Message posted on 24 Sep 2024 10:41 AM
The tv stays on when the skyq box goes into standby, I have them linked to turn off together when I press power off on skyq remote
I had the power in a surge protector initially but have plugged it directly into the socket now makes no difference
Don't have another TV to try
Will have a look at the other thing you mentioned
Message posted on 27 Sep 2024 11:01 PM
ive been having the same issue with my sky q 2tb box for the last few months. It can go days working fine then one day it randomly goes to standby a few times. Very annoying.
i finally spoke to sky tech support yesterday and they couldn't find a fault, not that they did any real tech support just said sending a new replacement box which arrived earlier today.
the replacement has been in place for around 12 hours now and already has gone in standby quite a few times. It's basically doing the same as the previous q box which again is very anoying.
I've changed the smart standby setting to off but doesn't seem to have worked.
Don't really know what to try now, do you still have this issue?
thanks
Message posted on 28 Nov 2024 07:21 PM
Hi. Just seeing if anyone found a fix for this? I'm having the same issue, across multiple replacement boxes. Be good to understand the fix.
