23 Sep 2024 10:52 PM
Ok so have seen other posts about this but nothing helps.
My SkyQ box will go into standby while watching live or recorded programs
It may go days without doing it, sometimes does it twice in 30 minutes.
I have had at least 2 replacement boxes, I have reset, hard drive reset and factory reset the current one
Turned off eco mode that is supposed to put it in standby when not in use.
I have updated the software on the box
Different cables have been used with each box
I have tried different hdmi sockets even though sky insist it will only work on hdmi sockets 1
I have "turned it off and back on again" lol, overnight so it is definitely gets a cool down.
It is the only unit on my TV stand so isn't overheating and to help air flow I have made a little stand so air can flow all around it.
This started about 3-6 months ago, so I'm thinking it's firmware causing it.
The replacement boxes are clearly refurbished units as the last one has finger prints all over it and the remote voice control didn't work.
Does anyone one have any idea why this keeps happening and more importantly how can it be fixed
Thanks Paul
sky Platinum VIP
24 Sep 2024 10:11 AM
If the issue is occurring after the box has been replaced several times perhaps the cause is external?
A few thoughts - maybe the TV is a cause? My TV will put the Q box into standby when I turn the TV off so maybe the TV is sending a standby signal occasionally? Try either swapping the TV - which tbf is a somewhat impracticable solution! - or turning off HDMI-CEC functionality.
Another thought is perhaps there is an issue with the mains? Maybe a spike is causing the box to go into standby. How you would test/check that I have no idea - maybe an extension lead with a mains filter?
24 Sep 2024 10:41 AM
The tv stays on when the skyq box goes into standby, I have them linked to turn off together when I press power off on skyq remote
I had the power in a surge protector initially but have plugged it directly into the socket now makes no difference
Don't have another TV to try
Will have a look at the other thing you mentioned
