4
This discussion topic has been answered Discussion topic: My Sky Q remote volume and power button aren't working.
This message was authored by: John240
My Sky Q remote volume and power button aren't working. All the other buttons are. I have tried doing the & &9 1&3 but then when itry to find my TV it says that my tv is not on the list. It is a Samsung and it has been working for the last 18 months.
I have disconnected everything and rebooted to no avail.
Any other suggestions?
Thanks , JOhn
Avatar for John240
This message was authored by: John240 Answer
Re: My Sky Q remote volume and power button aren't working.
@skylar01
It turns out my Samsung ocb box had become unpaired as well. Since everything runs through this box I assume it affected the sky volume as well. Try pairing your Samsung remote first. (Google it)
Thanks , JOhn
@John240 when you reset your remote have you tried saying that you do not know your model then trying all the options you are given for Samsung TV's
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for John240
I tried all 8 options. When I keyed in the actual model number it said it doesn't support that model number. Which is not true because as I said it worked before.
This message was authored by: Skyler001
This exact issue has happened to me. Suddenly my new Samsung tv which was working fine now isn't supported. What do we do????
Avatar for John240
@skylar01
