Discussion topic: Remote problems
Message posted on 02 Mar 2024 02:27 PM
Remote problems
My remote has to be waved about to connect to the sky tv box. Do I need a new one and if so how do I get it?
Message posted on 02 Mar 2024 02:41 PM
Re: Remote problems
@Ga1L1900
After checking the basics, ie; fresh batteries, re-pairing etc if your Sky Q remote is definitely broken/faulty, if you follow this link it should allow you to do some more troubleshooting and then it’ll send you to a form to request a replacement (apparently this is not available to customers in the ROI).
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment#get-in-touch
It may be quicker to purchase a new remote from a retailer or larger supermarket. If you do that as well as the above you’ll have a spare.
