Discussion topic: Multiple SkyQ Performance Issues
This message was authored by: JamesStewart13
Hi, I am having multiple issies with my SkyQ box. My BB speed is 500+mbps so not that.
I have the following:
- Netflix only opens to the red Netflix logo screen and the just hangs with a red spinning circle
- Often get a black screen for 5-10s or longer when changing channels
- Weirdly, been seeing more examples of picture and audio out of sync, makes everything look dubbed!
- Mega-slow when searching or browsing on demand catalogues and Sky cinema and on recordings
- Apps don't show images of the apps!
- Often no images in the Sky cinema pages when loaded up and when surfing it hangs
- Recordings or on demand often just come up with a black screen but audio is there
I've got the stage where I just watch Netflix and Prime via the TV app rather than SkyQ, and have even given up on a couple of programmes on Sky due to the performance. It feels like the hardware is near end of life. Not sure if this all common across the platform or it is just my box. We have a few recordinds I am loathed to lose! I think if I had to I may just cancel Sky.
Thanks!
Re: Multiple SkyQ Performance Issues
Hi @JamesStewart13
Age doesn't necessarily degrade a Q box.
Most boxes are in their senior years.
Try a Reset Settings in the Q box hidden menu.  See if this gives it an improvement.
Cancelling Sky subscription will cause the loss of all recordings, as will resetting the box (as @oldfella indicates) or having it replaced by Sky.  The hard drive is for time-shifted viewing and downloading, not archiving, and there's never been any guarantee of content retention.
