01 Feb 2024 02:45 PM
The internet to my tv has been lost somehow , cannot get on apps I have reset my router and still not connected it has been like this now for 2 weeks , I just feel a bit thick because I can't connect
01 Feb 2024 04:37 PM
@JanetMcDonnell wrote:The internet to my tv has been lost somehow , cannot get on apps I have reset my router and still not connected it has been like this now for 2 weeks , I just feel a bit thick because I can't connect
Hi @JanetMcDonnell do you mean your actual tv or the Sky Q box?
01 Feb 2024 05:00 PM
I think the w box because I can't get my apps on
01 Feb 2024 05:12 PM
Try a Network reset on the Q box.
Found in Q box Home - Settings - Setup - Network.
01 Feb 2024 05:14 PM
Thanks for quick reply but I can't find wps button on the router
01 Feb 2024 06:37 PM
If you are on Sky Broadband with a Sky Q router see location of WPS button.
03 Feb 2024 12:43 PM
@oldfella @Thanks a lot I'm now connected
