Discussion topic: Multi room not working
This message was authored by: MarkReeve87
My sky q box is working and my internet but my multi room box won't connect to the activation server
Re: Multi room not working
Hi @MarkReeve87
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Avatar for MarkReeve87
Got it fixed
@MarkReeve87 wrote:
Got it fixed
How @MarkReeve87 ?
This message was authored by: RebeccaC1
  1. How?
This message was authored by: Dotty62
My multi room box keeps saying technical fault please try later
My sky multi room box keeps saying technical fault please try again later.... I have turned box off and reset but still saying the same
This message was authored by: Tuckmill54
No satellite connection
@Tuckmill54
Are you seeing a No satellite signal message on the screen? If it displays no satellite signal take a look at the troubleshooting here
It may then give you the opportunity to arrange an engineer to check the alignment of your dish. Just to make you aware, if you’re on a communal dish system in the UK you’ll have to contact your landlord or building management company rather than Sky.
This message was authored by: Wendy311
My mini box say no satellite signal. But my sky q box working
@Wendy311 Have you tried rebooting your main Q box ie
then
rebooting your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
