Discussion topic: Moving sky q
This message was authored by: Carter2020
Moving sky q
Movine sky q box
Re: Moving sky q
@Carter2020  And your question is?
we are customers here not sky support so without more information we can't help
Re: Moving sky q
@Carter2020 wrote:
Movine sky q box
Hi @Carter2020
I'm sure you are aware that your Q box must be connected to the Satellite dish cables at all times.
If the new location is at an exterior wall and there is a feasible route to the Satellite dish then it's possible that Sky could relocate the dish cables.  This would cost in the region of £65.
If you are moving it just a short distance you could consider using satellite extension cable kits which are readily available at various lengths.
