Discussion topic: Moving equipment
This message was authored by: AdeleW
Moving equipment
I am refurbing and want to move my tv to another wall. The Q box is cabled and the engineer also plugged it into the Wi-Fi router. I don't really want to relocate the Wi-Fi. Does the Q need to be cabled in or can it work wirelessly!?
Re: Moving equipment
Hi @AdeleW Yes your SKYQ box will connect to your router via wifi, you will need to change your network settings to connect to your broadband router.
Avatar for AdeleW
Thank you that's a relief!
Hi @AdeleW
Bear in mind that the two cables that go from the Satellite dish into the back of the Q box still need to be connected.
