Discussion topic: Moving equipment
Message posted on 11 Aug 2023 08:12 AM
Moving equipment
I am refurbing and want to move my tv to another wall. The Q box is cabled and the engineer also plugged it into the Wi-Fi router. I don't really want to relocate the Wi-Fi. Does the Q need to be cabled in or can it work wirelessly!?
Message posted on 11 Aug 2023 08:14 AM - last edited: 11 Aug 2023 08:15 AM
Re: Moving equipment
Hi @AdeleW Yes your SKYQ box will connect to your router via wifi, you will need to change your network settings to connect to your broadband router.
Message posted on 11 Aug 2023 09:12 AM
Thank you that's a relief!
Message posted on 11 Aug 2023 10:10 AM
Hi @AdeleW
Bear in mind that the two cables that go from the Satellite dish into the back of the Q box still need to be connected.
