Discussion topic: Moving cable
This message was authored by: Sm2802
Message posted on 04 Feb 2024 03:45 PM
Moving cable
I need to move the cable from sky dish, need it on the other side of front room. Will sky do this?
Find out more
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 04 Feb 2024 05:00 PM
Re: Moving cable
@Sm2802 Sky will do this but sat a cost of £65 if it is purely inside that needs extending then you can buy extension cables that you can then do it yourself see below
