1
This discussion topic has been answered Discussion topic: Q box problem
This message was authored by: decor8
Q box problem
q box would not pause or rewind.Now it will  not record.saying failure due to technical fault.
This message was authored by: Laing1 Answer
Re: Q box problem
@decor8 Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Re: Q box problem
