Discussion topic: Moving cable
This message was authored by: Sm2802
Moving cable
I need to move the cable from sky dish, need it on the other side of front room. Will sky do this?
Re: Moving cable
@Sm2802 Sky will do this but sat a cost of £65 if it is purely inside that needs extending then you can buy extension cables that you can then do it yourself see below
https://www.amazon.co.uk/s?k=satellite+cable+extension&crid=XHAY4PPOYZ35&sprefix=sate%2Caps%2C103&re...
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
