Discussion topic: Moving Home Issue
Message posted on 20 Jun 2024 11:36 AM
Moving Home Issue
I've requested a home move through the sky vip section. The problem is I move out on the 12th of July & move into my new home on the 25th of July.
For some reason Sky are sending a new/replacement Sky Q box to the new home address & not the one I'm currently living in.
How can this be fixed?
Message posted on 20 Jun 2024 11:39 AM
Re: Moving Home Issue
@AdamMcArdle For security reasons Sky will only deliver to the address the hardware will be registered to
no exceptions
Message posted on 20 Jun 2024 11:42 AM
Yeah but I haven't moved my address yet so all my hardware is registered to my current address not my new home address.
it says on the app & shows my current address.
is the conversion kit a new Sky Q box?
Message posted on 20 Jun 2024 11:47 AM
Please note the image has been removed as it contains personal info
Message posted on 20 Jun 2024 11:48 AM
A conversion kit is merely an ethernet cable presumably because full fibre fttp is available
Message posted on 20 Jun 2024 11:49 AM
@AdamMcArdle You registered your new address during the home move request therefore sky will send all equipment to that address even though the app still says your current address
once you move you will need to call sky to update the address on the app
Message posted on 20 Jun 2024 11:56 AM
Ok thanks for that.
do you know when they send a replacement sky q box? Why would a new box be required if I can just take it with me to my new address?
Message posted on 20 Jun 2024 12:01 PM
@AdamMcArdle wrote:
Ok thanks for that.
How old is your current sky q box ?
Is it uhd compatible?
Have you requested UHD ?
Message posted on 20 Jun 2024 12:07 PM
Its around 7 years old & I haven't requested UHD so not sure why they want to send me a replacement box
Message posted on 20 Jun 2024 12:14 PM
Are you referring to sky q satellite tv or an old sky q router?
Message posted on 20 Jun 2024 12:16 PM
Message posted on 20 Jun 2024 12:29 PM
Unless its to do with shutting down SD channels and broadcasting the remaining HD channels on dvbs2. Not sure that a q box that old would have dvb s2 instead dvb s. Others here would have more insight
@nigea99 is sky sending out new q boxes due to shutting done sd and not sure if it means transferring all broadcasts to dvb s2 .and whether a 7 year old sky q box would have a dvb s2 thanks
Message posted on 20 Jun 2024 12:36 PM
@AdamMcArdle wrote:
Yeah i mean my Sky Q box, they are sending me a replacement one since i have requested a home move.
Are you sure it is a SKY Q TV box - SKY do not usually send TV boxes on home move.
The image you posted has not been approved for public view as it contains personal informantion but that refers to Broadband not TV
Message posted on 20 Jun 2024 12:43 PM
All SKY Q and SKY HD boxes accept DVB-S2 signals (which the HD channels already use)
It really is only the very old SD only boxes that are affected
Message posted on 20 Jun 2024 12:49 PM
Yeah the email just said my replacement sky q box is on its way
