Discussion topic: Move outside cable
This message was authored by: jackysnowdon
Move outside cable
Dear Team,
I had Sky fitted just over 3 years ago.
I need to move my side gate, however when looking the cable is through the gate and I can not remove the gate with rmthe xable where it is
Re: Move outside cable
@jackysnowdon
Cable for what, Tv or Broadband and I'll move your post to the correct board. I've removed your duplicate thread as it's not needed.
This message was authored by: bob1234
@jackysnowdonI assume this is the cable from your dish although Sky will do it their standard charge is about £65 as the dish and cable is yours you could employ an independent satellite installer to do it, but get a quote first.
This message was authored by: Invisiblename
@jackysnowdon wrote:
Dear Team,
Would love to see a photograph of this - sounds like a very strange cable routing!
I am just another Sky customer!
Avatar for jackysnowdon
hi @jackysnowdon
The Image does show how you might have a problem, as the cable appears to have needed to go over the stationary part of the gate framework.
As we can only see the section around the gate it is a bit difficult to tell what options you have currently for routing the cable.
I guess a question that an installer might have is whether or not they can route a new cable as you wish  suitably  before you have your gate moved - maybe an option woud be live without Satellite TV between the Gate being moved (just cutting the cable after switching the box off) and an installer coming to route a new cable after the gate is moved.
It will, probably,  depend on where you think the cable can be routed
SKY are likely to charge - although they may not & you may be better getting a quote from an independent installer (who are more likely to work to dates around you)
Nice gate, but can't see where the problem is
