Discussion topic: Move outside cable
Message posted on 17 May 2023 08:55 PM
Move outside cable
Dear Team,
I had Sky fitted just over 3 years ago.
I need to move my side gate, however when looking the cable is through the gate and I can not remove the gate with rmthe xable where it is
Message posted on 17 May 2023 09:04 PM
Re: Move outside cable
Cable for what, Tv or Broadband and I'll move your post to the correct board. I've removed your duplicate thread as it's not needed.
Message posted on 18 May 2023 07:34 AM
@jackysnowdonI assume this is the cable from your dish although Sky will do it their standard charge is about £65 as the dish and cable is yours you could employ an independent satellite installer to do it, but get a quote first.
Message posted on 18 May 2023 11:19 AM
@jackysnowdon wrote:Dear Team,
Would love to see a photograph of this - sounds like a very strange cable routing!
Message posted on 18 May 2023 02:16 PM
can
Message posted on 18 May 2023 02:56 PM - last edited: 18 May 2023 02:58 PM
The Image does show how you might have a problem, as the cable appears to have needed to go over the stationary part of the gate framework.
As we can only see the section around the gate it is a bit difficult to tell what options you have currently for routing the cable.
I guess a question that an installer might have is whether or not they can route a new cable as you wish suitably before you have your gate moved - maybe an option woud be live without Satellite TV between the Gate being moved (just cutting the cable after switching the box off) and an installer coming to route a new cable after the gate is moved.
It will, probably, depend on where you think the cable can be routed
SKY are likely to charge - although they may not & you may be better getting a quote from an independent installer (who are more likely to work to dates around you)
Message posted on 18 May 2023 05:20 PM
@jackysnowdon wrote:can
Nice gate, but can't see where the problem is
