Discussion topic: Missing channels
This message was authored by: Sue653
Missing channels
Every few days both bbc1 and bbc2 are missing from the guide, when I click  on them it says technical issue. I've run tests and that comes back saying all ok
any help appreciated
Re: Missing channels
@Sue653
What tests?
Firstly try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Avatar for Sue653
Thanks for advice,bbc1 came back but bbc2 still wasn't working and a message came up this time, saying 'this channel is affected by a problem with your satellite signal'
@Sue653
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Avatar for Sue653
Thank you, tried what you said, booked an engineer
