Discussion topic: Missing channels
Message posted on 31 Jul 2025 01:39 PM
Missing channels
Every few days both bbc1 and bbc2 are missing from the guide, when I click on them it says technical issue. I've run tests and that comes back saying all ok
any help appreciated
Message posted on 31 Jul 2025 01:42 PM
Re: Missing channels
What tests?
Firstly try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 31 Jul 2025 06:20 PM
Thanks for advice,bbc1 came back but bbc2 still wasn't working and a message came up this time, saying 'this channel is affected by a problem with your satellite signal'
Message posted on 31 Jul 2025 06:21 PM
@Sue653
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
Message posted on 31 Jul 2025 06:47 PM
Thank you, tried what you said, booked an engineer
