Discussion topic: Miss hazel knowles fault box
This message was authored by: Hazel521
My Sky Q box is is cutting off when it gets hot the box I need the engineer to come and check it over
Re: Miss hazel knowles fault box
@Hazel521
Typically that won't happen: Sky replaces dodgy hardware by doorstep swap-out.
@Hazel521
The box shouldn't get so hot as you can't still rest the palm of your hand down on the top of it.
If Sky arrange a 'doorstep box swap' have the box disconnected before the courier arrives. Remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
