Discussion topic: Minibox not working
This message was authored by: TonyBontoft
Minibox not working
I have a minibox and booster but the box isn't connecting to the network, it can't find IP address
Re: Minibox not working
Hi @TonyBontoft
Is it a Sky Q booster you have and if so where is it located?
Avatar for TonyBontoft
Yes it is, about 8 feet from the mini box
Hi @TonyBontoft
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
  1. Hold the WPS button on your booster for 3 seconds until it flashes amber. Then hold the WPS button on the front of your main Q box for 3 seconds until it flashes amber - You'll need to do it within 2 minutes.
  2. After a few minutes, the connected light on the booster should  turn green. You're all set up.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
Hi @Old fella, thanks for your help. I tried your suggestions without success, I'm afraid. Had to resort to calling Sky, the chap I spoke to went through the same processes but it appears that my main Sky Q box is not connecting to my network, despite repeated attempts. I have booked an engineer's visit (5 weeks time!).
This message was authored by: kirsty_
i'm having the same issues and have tried calling sky.  what number did you use to actually speak to someone and book an engineer?
Who is your broadband supplier @TonyBontoft ?
It's B4RN (broadband for rural networks)
Sorry Kirsty, this system won't allow me to send the number but if you go through the network reset system on your tv you'll find it there
