Discussion topic: Minibox buffers
Message posted on 08 May 2024 04:25 PM
Minibox buffers
During watching apps such ss netflix my tv connected to the minibox kreps buffering. I need to hrt my connectivity chrcked
Message posted on 08 May 2024 07:07 PM
Re: Minibox buffers
@Gillhutcho have you tried rebooting your router when that is up and running
reboot your main box and when that is up and running
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 08 May 2024 08:00 PM
Re: Minibox buffers
Hi @Gillhutcho
try a Network Reset on the mini.
Message posted on 10 May 2024 10:22 AM
Re: Minibox buffers
I will try this.
however things seem to be weather effected so may be that i just have to put up with it!
Message posted on 10 May 2024 10:23 AM
Re: Minibox buffers
Will give it a try
