Discussion topic: Mini box
This message was authored by: Mandeepkaur86
Mini box
I want to talk about my mini box. Ots not working today.
Re: Mini box
Go ahead, you can discuss it with the other customers here.
There's an ongoing thread here: https://helpforum.sky.com/t5/Sky-Q/No-satelite-signal/td-p/5185796
Re: Mini box
@Mandeepkaur86
Is the issue connected with this mornings Sky Q issues discussed here?
This message was authored by: Sharona21
Re: Mini box
My mini box isn't loading and the accessible option has froze on my screen and none of the keys on the remote work please advise?
there was a network issue all day and has only resumed to the main box now
Re: Mini box
@Sharona21 try the following... to sort the accessibility problem
Unpair their Sky Q remote from the box by holding 4&6
Wait for the remote to flash you should then be able to dismiss the information screen by clicking on Skip & set up later
Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control your TV.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
