Discussion topic: Nuremberg in UHD
Message posted on 10 Jan 2026 05:34 PM
Nuremberg in UHD
Nuremberg is available on my sky Q box to download in UHD, but not HDR. This also happened to me last week when I wanted to watch 28 Years Later (although the HDR option for that film is now appearing). Do the HDR options come later than the initial release or is there an issue?
Message posted on 10 Jan 2026 06:56 PM
Re: Nuremberg in UHD
Having a issue downloading this movie as well. My settings are for default UHD download, but when I click download I get an error message saying "because of a technical issue, you download could not be completed. please try again later". I tried changing the format to HDR, but got the same error message, so perhaps there is a temporary issue with all downloads for this movie?
Message posted on 10 Jan 2026 07:01 PM
@plumpumpkin Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 10 Jan 2026 07:08 PM
hi @Petruchio
I am also only seeing the non HDR UHD version.
Sometimes there can be delays in uploading versions so it may be worth waiting till Monday to see if one gets uploaded
After that best to email Viewer Relations : viewerR@Sky.uk
Message posted on 10 Jan 2026 09:26 PM
I was having the exactly same message now with this movie. Restarted the box and internet connection and it's now working
