This discussion topic has been answered Discussion topic: Mini box stuck on this
Message posted on 26 Sep 2024 02:31 PM
Message posted on 26 Sep 2024 02:35 PM
Sky have suggested the following...
- Unpair their Sky Q remote from the box by holding 4&6
- Wait for the remote to flash
- Then dismiss the information screen "Skip & set up later"
- Hold 1&3 to repair the remote control
If 4&6 does not allow you to clear the information screen, try holding 7&9 to reset the Sky Q remote then hold 1&3 and follow the on-screen setup journey to allow the remote to control the TV.
Message posted on 26 Sep 2024 03:25 PM
Re: Mini box stuck on this
Brilliant it worked but thank you thanks
Message posted on 26 Sep 2024 04:03 PM
I like it when a plan comes together.
