3
This discussion topic has been answered Discussion topic: Mini box return
This message was authored by: EYPATTY
Mini box return
I am returning sky mini box in their packaging. Do I need to send the cable and plug lead they installed with it.
Re: Mini box return
@EYPATTY
Send back the damaged one. Sky won't be sending it out to anyone else.
Re: Mini box return
@EYPATTY
If you have got these you can do if you any but I don't believe it is that important.
Just make sure you get and keep for at least 6 months the proof of posting.
Avatar for EYPATTY
Level 3 icon
Re: Mini box return
Thanks for that. Forgot to say have I to return the remote as well. Could do with keeping it as the main one is cracked and taped up.
Re: Mini box return
@EYPATTY
Answered - Go to Answer
