Discussion topic: Mini box not working
This message was authored by: Beanie42
My mini sky box isn't work keeps saying no signal
Re: Mini box not working
Hi @Beanie42   "No signal" normally means that you TV is not on the HDMI input for the Sky Q box.
Avatar for Beanie42
Hi @MightyQuinn
Have tried it an it's still not working
Hi @Beanie42
First make sure that the Television is switched on and is switched to the HDMI input to which the Q box is connected.
Then with the Q box switched on with green led illuminated
Press
Home 1 0 8 0 Home
on the Q box remote control.
This will change the Q box to standard resolution which will should work for all TV’s.
Avatar for Beanie42
Hi @oldfella
have tried this an still no joy 🙈
@Beanie42 wrote:
Hi @oldfella
Have you another HDMI cable you can try @Beanie42
