3
This discussion topic has been answered Discussion topic: Sky Cinema Pin request
This message was authored by: NewFormat
Hello,
Where i can find the pin for sky cinema movies? im using small tv device.
This message was authored by: MightyQuinn Answer
Re: Sky Cinema Pin request
Hi @NewFormat   On you Sky Q Main box remote, press Home -> Settings -> System info -> Viewing card number. The delivery PIN is the last 4 digits.
@NewFormat
What do you mean by this, are you using your Sky Q remote because if so it is usually the last 4 digits of your viewing card number.
Avatar for NewFormat
Where i can  find a TV card?
